Autor Tema: The Altmann Tera-Player  (Leído 1480 veces)
nepro
  • nepro
« en: Febrero 06, 2012, 11:00:31 »
Por sólo 840€ ...  :o
http://www.tera-player.com/
An Interview with Charles Altmann
http://www.headfonia.com/an-interview-with-charles-altmann/
Specification:
size: 57 x 57 x 18 mm
weight: 80 grams
case: all aluminum black anodized, laser engraved
front rear plates: 2mm aluminum black anodized, CNC machined
battery: Motorola LI-ION 700mAh
charging: mini-USB port 300mA, monitored by red LED
playtime on single charge: >12h (15h tested with 6 years old battery)
charge time: 2h 80%
Storage: SDHC card slot with 4/8/16 or 32 GB SDHC
currently testing SDXC cards with 64GB (all SDXC cards must be formatted to FAT32 for use in the Tera-Player)
Supported file type: WAV stereo 16-bit and 24-bit
Supported sample-rates: 44.1 / 48 / 88.2 / 96 / 176.4 and 192 kHz
headphone outputs: silver plated contacts, 2 separate outputs: teramega and superduper, can be used simultaneously
recommended headphones: Koss Porta-Pro, Kramer mod
main chip: ARM Cortex
oscillators: 2 separate precision Golledge crystal oscillators
DAC: modified NOS Philips R2R with current output
Oversampling: Zero
I/V conversion: Burr-Brown
headphone amplifiers: Burr Brown
navigation: tactile pad with 5 stainless steel buttons, gold plated contactor foil, hand assembled
volume control: 32-bit digital
navigation commands: next previous track / album / artist
supports iTunes® music library structure
5 (five) years limited warranty
made in Germany
victor_cc
  • Disfrutando de la música
Re: The Altmann Tera-Player
« Respuesta #1 en: Febrero 06, 2012, 12:11:13 »
Curioso aparato. Me gustaría poder escucharlo pero más de 800€ por un reproductor que sólo soporta wav y no tiene pantalla....... Porque estoy con el móvil y no puedo expresar mis sentimientos pero se me están saliendo los ojos de la cara.
Y lo dice alguien que está muy contento con su qls qa350 (sólo wav y pantalla minúscula de dos líneas) pero es que esas son las dos pegas que tiene y por poco más de 200€ me parece asumible si el sonido es bueno pero 800...
Estamos locos? :)
Re:The Altmann Tera-Player
« Respuesta #2 en: Febrero 06, 2012, 12:38:04 »
Pues para escucharlos con koss Porta-Pro, como recomienda el fabricante, pues como que no pago 800 euros. Los koss Porta-Pro son estupendos para lo que son, pero no para gastarte ese pastizal en ellos. Como se suele decir "vale más el collar que el perro."
  • Administrador
« Respuesta #3 en: Febrero 06, 2012, 13:13:44 »
Parece un reproductor un tanto extravagante, sólo para frikis ;)
