VU-Meter
Iniciado por musicalia, Diciembre 02, 2009, 07:20:02
lord.camilo
Muy interesante el artículo del Señor Nelson Pass, me lo apunto para leerlo y asimilarlo con más calma :D. Muchas gracias Raúl.
Cuanta información  :o :o
...para no aburrirse en el puente.
Bajaros especialmente el último: opamp_distortion.pdf
Sorry again! My lord camilo  :birras:
P.D.- http://www.analog.com/library/analogDialogue/archives/39-05/Op_Amp_Applications.zip
...más:
Uno en clase A con dos etapas:
[This discrete operational amplifier consists of a differential input amplifier (build with a 2SK389 dual JFET - Q1) with a current source (Q2) and a single ended class A output stage with a pnp bipolar transistor (in my design a ZTX550 - Q5) also with an active current source (Q4). The power supply voltage is, for normal operational amplifiers unusual, ±25V – unlike to the design of moamps who operates with the normal ±15V. The npn transistor Q3 make sure that both current source transistors sees a constant voltage at the basis (constant base-emitter voltage ≈0.65V).]
http://www.rstaudio.de/FreqWeiche/DiskreterOP.pdf
Replacement for Dual-JFET 2SK389 and 2SJ109
[The Toshiba Dual-JFETs 2SK389 (n-channel) and 2SJ109 (p-channel) are no longer in production. Nevertheless specially these types are in use in nearly every relatively new design from Nelson Pass. Fortunately the corresponding single JFET's are still in production and therefore it is easy to replace the Dual-JFET's. To do that the single transistors must be matched and thermally coupled. In a new design it is also possible to use the SMD replacement for the Dual-JFET.]
    Original    Replacement    Comment
n-Channel    2SK389 -    2× 2SK170    identical single JFET
                                2× 2SK370    replacement for 2SK170
                                2SK2145    Dual-JFET, SMD, both sources internally connected
p-Kanal    2SJ109 -    2× 2SJ74    identical single JFET
                               2× 2SJ108    replacement for 2SJ74
Dr.Strangelove
Hola
Yo también estoy interesado en este tema, especialmente los vúmetros de aguja, en esta página hay muchos proyectos
http://www.sonelec-musique.com/electronique_realisations.html
Concretamente en este apartado
Affichage audio (vu-mètres, crêtemètres, phasemètres, oscilloscopes)
Pero tengo 2 dudas:
la 1ª- ¿que es mejor conectar los vúmetros en los RCA o en los bornes de altavoces?
y la 2ª aunque es un poco reincidente sobre la 1ª, si los vúmetros llevan alimentación propia a través del operacional no debería afectar para nada al sonido ¿ O si ?
Hola Dr.Strangelove,
En este post ya tienes la respuesta:
http://www.auriculares.org/foro/index.php/topic,2759.msg32679.html#msg32679
Como ves el circuito sirve tanto para línea como para altavoz, ya en el post te dice que debes evitar los de tipo puramente pasivo, que son los que degradan la calidad de sonido. Por ejemplo este yo no lo usaría:
http://www.sonelec-musique.com/electronique_realisations_vumetre_010.html
Podrías usar este para línea, aunque el que te recomendé al principio es mejor:
http://www.sonelec-musique.com/electronique_realisations_vumetre_001.html
Y este en la salida de altavoces, pero continúo prefiriendo el primero. Tú eliges:
http://www.sonelec-musique.com/electronique_realisations_wattmetre_audio_001.html
Si te gustan más con leds´s este tambien es recomendable. Para línea:
http://www.knollep.de/Hobbyelektronik/projekte/38/index.htm
Aparte de esto, como hemos metido también el tema de Amplificadores Operacionales Discretos, quizá este documento sea de interés para quien quiera hacerse alguno:
http://www.epanorama.net/schematicsforfree/pdf_redirect.php?url=http://www.epanorama.rackhost.net/schematicsforfree/Audio/Circuits/Pre-Amps/DISCRETE_OPAMPS.PDF
Dr.Strangelove
Lo tenía empezado y al fin lo he terminado.
Por seguir abundando en el tema de los operacionales con componentes discretos, y algo más:
http://www.mediafire.com/file/o1gn2inmn3i/Simple DOA & Clean Supply.pdf
