Pues eso, abro el hilo para la compra comunitaria de las rejillas que disturbed descubrió en la página británica esta:
http://www.themeshcompany.com/acatalog/Stainless_Steel_A5_Sized_Sheets.html
Serían, como veis, del estilo de las sr225i.
#10 Stainless Steel Woven Wire A5 Sheet
Ref: WSS10-A5
An A5 (210mm x 148mm) sized sheet of Stainless Steel woven wire mesh.
This material is heavy duty and is well suited to engineering and hard working applications. It is at the coarser end of the heavy duty bracket and it is a great material for sculpture and model making. As it is Stainless Steel it will last, assuming is is appropriate conditions, for many years.
Mesh Count: #10 mesh - 10 wires or holes per linear inch.
Wire Diameter: 0.56mm
Aperture: 1.98mm - this is the hole size and it is square
Open Area %: 60.8%
The wires on this material are thick and it can easily be cut with heavy tin snips. Regular tin snips may also be used but would require a little more effort than it would if you used the afore mentioned heavy variety. We can cut this simply on our guillotine so please contact us with any specific size that you may have. This material is also available in Pre-Cut A4 Sheet if that is closer to the size that you may need.
Price: £2.99Buy 2 A5 Sheets and Get A Third Absolutely Free!!
Lo dicho, a priori la malla tamaño A5 cuesta 2,99 libras, pero hay que tener en cuenta que está la oferta esta de llévate 3 y paga 2 (como en las pizzas
) y que los gastos de envío serían compartidos y bastante razonables. Actualizo aquí la lista a la espera de que se anime alguien más.
LISTA DE INTERESADOS:
1.- Disturbed
2.- Antonius Block
3.- Phonotone
4.- Yugas
5.- Santojob
6.- Sdpm
7.- Quimi
8.- Eduardo
9.- GTO
10.- Eferbel
11.- Txarly
12.- Migara
13.- Picodeloro (2 unidades A5)
14.- Summermaster
15.- Caromire
Abrazo
