Autor Tema: Sennheiser HD800 - Ya están aquí!  (Leído 117099 veces)
    • hitoridekimasu
Re: Sennheiser HD800 - Ya están aquí!
« Respuesta #1 en: Enero 08, 2009, 09:26:36 »
Aunque posiblemente bajarán de precio, acabo de comprar unos HD600 para hacer las correspondientes comparativas con los HD800 (cuando salgan a la venta, claro).
Ahora a esperar. No creo que tarden demasiado en estar disponibles.
Saludos ;)
« Respuesta #2 en: Enero 08, 2009, 09:33:22 »
;D Joer, pues hasta la foto que yo había visto por ahí coincide...
parodius
« Respuesta #3 en: Enero 08, 2009, 09:35:19 »
Slurp!!. A ver si bajan el precio de los HD650 y vemos lo que se puede hacer.....
« Respuesta #4 en: Enero 08, 2009, 09:37:56 »
La verdad es que son un poco feos para mi gusto... :P :P :P
¿Cuanto costarán?
    • hitoridekimasu
« Respuesta #5 en: Enero 08, 2009, 09:38:18 »
Esto es lo que cuenta el brochure:
The story of the Sennheiser HD 800 began with a dream: of developing headphones that go way beyond conventional equipment to become music phones, or even perfect sound phones. The dream of creating a hi-fi device that sounds as brilliant, clear, and undistorted as if you were sitting right next to the source. The dream of creating an acoustic experience more incredible than anything ever heard through dynamic headphones: in spheres that no other category is capable of reaching—right there where perfection begins.
We couldn’t go beyond physical boundaries—but we did cross the boundaries of thought. The HD 800 is equipped with a completely new transducer and only the very finest of materials have been installed: each part carefully inserted by hand. We are talking about manufacture in the truest sense of the word, right from the initial drafts to individual handcrafting “made in Germany”.
Above all, the Sennheiser HD 800 truly personifies the creative force of the company that created it: by displaying the passion for perfect sound that has been driving Sennheiser innovation over 60 years.
The principle of spatial listening. The impression of spatial listening is created by a minute time lapse with which one and the same sound wave arrives at the inner ear. Ideally, the sound waves produced by a hi-fi sound system reach the listener at an angle of 60 degrees. The sound waves do not reach the ear straight on, but through a slightly angled sound front. This causes some of the sound impulses to reach the nerve ends of the inner ear earlier than others. The resulting time lapse is a matter of split seconds, but it is exactly this phenomenon that gives the impression of spatial listening.
Spatial listening with the HD 800. Wearing the HD 800 you enjoy much more than just a sound experience of out-standing brilliance. You experience a form of spatial listening never heard before. You have the feeling of being in a studio together with Thelonius Monk or actually being present at a rehearsal of the Berlin Philharmonic. The HD 800 makes spatial listening possible through a combination of the large transducer surface and the angle at which it is suspended. The slightly angled sound front effectively simulates the principle of the spatial sound experience. No other manufacturer comes as close to producing a natural sound experience as Sennheiser with the HD 800.
The superiority of the HD 800 is based on a completely new principle, right at its very heart: The transducer is designed in the shape of a ring. Basically, the larger the surface of the transducer the purer the sound—particularly when it comes to the low notes. A large surface area, however, also generates disruptive spurious oscillation at higher frequencies, so-called eigenmodes. This is primarily due to the fact that conventional-sized transducers do not have a satisfactory way of controlling high-frequency oscillations. The ringed shape of the new transducer effectively solves this dilemma: Its broad area oscillates in an extremely controlled way due to the large coil and the two supporting surfaces. This results in a previously unheard-of degree of freedom from distortion and thus the greatest purity and brilliance of sound.
And when it comes to the naked technical facts, the HD 800 doesn’t save on superlatives: The 56-mm-wide transducer is the largest of its type. The same goes for the aluminum coil (40 mm) and the 42-mm magnet system.
Ring transducer. In contrast to a full-sized transducer, the ring-shaped transducer utilized in the HD 800 greatly enhances the control of the oscillating surface. This results in a more voluminous sound wave and thus far greater clarity!
Conventional transducer. Unwanted spurious oscillation can occur in a conventional, large transducer due to eigenmodes. Even resources such as increasingly sophisticated Duofol laminations are unable to completely negate these physical limitations.
    • hitoridekimasu
« Respuesta #6 en: Enero 08, 2009, 09:40:37 »
Dicen que el precio será de 1400 USDolar.
Esperemos que sea algo inferior, pero dudo que en un principio así sea.
Saludos  ;)
« Respuesta #7 en: Enero 08, 2009, 09:46:06 »
Eso me habían dicho y así es, 1400 dólares. Después de que vendan unos pocos y la demanda se estanque, irán apareciendo por ahí a precios mejores.
Lo que no entiendo mucho es por qué mucha gente piensa que los modelos antiguos van a bajar de precio. Si los dejaran de fabricar, pues vale, así se quitan el stock ya fabricado de encima, pero si van a seguir en producción, no tiene por qué cambiar el precio un solo euro. Que sepamos ni los HD650 ni los HD600 van a dejar de fabricarse.
parodius
« Respuesta #8 en: Enero 08, 2009, 09:55:33 »
@Torpedo - Hombre,en mi opinión no veo tan descabellado el tema de que los modelos antiguos bajen de precio aunque no dejen de fabricarse. Es lo típico en el mercado y sucede con casi todas las cosas... Cuando sale algo nuevo y con mas prestaciones aunque sea mas caro va a haber gente que lo compre en detrimento de otros modelos inferiores y mas antiguos.
Todos sabemos que el precio final de los productos esta muy inflado y si no quieren comerse el stock que se va a ir generando al tener un producto nuevo, no les va a quedar mas remedio que bajar el precio...
Saludos!!!
dexon
  • onofre
« Respuesta #9 en: Enero 08, 2009, 10:03:42 »
Os habeis dado cuenta que en las fotos esta conectado a un Benchmark DAC ?
« Respuesta #10 en: Enero 08, 2009, 10:04:08 »
Salvo que saquen una gama completa basada en el HD800, dudo que los HD6XX dejen de fabricarse.
Azazel
« Respuesta #11 en: Enero 08, 2009, 10:11:05 »
Puf la que se ha liado... en menos de 24 horas ya hay varios hilos de Head-Fi con 200 post  :o
Voy a intentar mover mis "hilos" a ver si consigo saber cuándo va a haber en España, a qué precio y... si habrá unos en mi casa  :-X
    • Fotoblog
« Respuesta #12 en: Enero 08, 2009, 10:20:34 »
Yo no creo, ni que dejen de fabricarse ni que bajen de precio, ya que son gamas distintas. Son simplemente un modelo tope de gama que no tiene porque influir en el resto.
« Respuesta #13 en: Enero 08, 2009, 10:30:28 »
Exacto. Cuando salieron los HD650 los HD600 no bajaron de precio. Han tenido que pasar años hasta que en algunas tiendas online puedes encontrar los 600 por alrededor de 180 euros, eso buscando y rebuscando. Lo normal es que cuesten rondando los 220. Yo pagué en tienda física por mis HD600, años antes de que salieran los HD650 unos 230 euros. EMO no creo que los precios de los 600/650 cambien sustancialmente salvo que decidan dejar de fabricarlos.
La verdad es que lo del "ring radiator" me ha quitado un poco la curiosidad. No digo que vayan a sonar mal, seguro que suenan estupendamente, pero no me parece una cosa suficientemente interesante como para ir corriendo a soltar 1000 eurazos para probarlos. Creo que me esperaré a que bajen de precio y a que más gente, sobre todo los que no tienen intereses comerciales y sí algo de criterio, cuenten qué tal suenan.
enos
« Respuesta #14 en: Enero 08, 2009, 10:46:59 »
Totalmente de acuerdo... Son gamas muy distintas.
Vaya, por fin el misterio desvelado. La verdad es que hace tiempo que la gente esperaba un nuevo auricular electrodinamico que ofreciera - sobre el papel -estas prestaciones. Me pregunto que tal ira balanceado  ;D
Mmmmm, tengo que resistir, tengo que resistir  :o
Sennheiser 1, AKG 0...
Y desde luego soltaria esta pasta para un fabricante de este calibre (lo siento, pero Grado no es lo mio).
Ouch, 2009 va a ser de infarto  ;D
